Activity Forums Blackmagic Design 5.2.2 some question
  • Bill Buchanan
    November 11, 2005 at 12:33 am
    Bazino:
    Good idea. Thanks for the tip. I’ll give it a shot.
    Bill Buchanan
  • Matt Dowling
    November 11, 2005 at 9:55 am
    Hi Bill,
    Baz really knows his stuff. If i get a mail from him with an issue he has seen i know we have a bug even before we try to repo (-:
    Seriously though, he is probably the best beta tester i have, EVERY time he has reported something, he has been right and his investigations and descriptions allow us to track the bug down very quickly and do a point update.
    Cheers,
    Regards,
    Matt
    Blackmagic Design
  • Yves De muyter
    November 12, 2005 at 10:11 am
    And an even better solution I use is to use Norton Ghost or PartImage and make a copy of a freshly installed XP system. A lot less work than switching hard drives !
    Takes some 10 minutes to restore an image…
    -Yves
  • Bill Buchanan
    November 12, 2005 at 6:03 pm
    Matt:
    No doubt Baz knows his stuff. Since there are a relative few having the crashing problem, I wonder if all or most of us are working with long-form projects with many hundreds or thousands of clips in the bins (and/or on the timeline)? Well known for its sorry memory-handling ability, I’m convinced my PPro 1.5 problems are somehow memory-related, since the project that’s giving me all the grief features a 40mb project file and over 5,000 clips in the bins.
    As a test, I created a New Project with the same settings (10-bit Uncmprsd, NTSC, etc) and imported 100 or so clips. Tried everything I could think of the make it crash and couldn’t.
    I continue to beseech all the gods that PPro 2.0 will be 64-bit and your BMD drivers would quickly support it. Perhaps only then will those of us working in long-form be allowed to join the rapture.
    Bill Buchanan
    Buchanan Film Co.
    OS: WinXP Pro, sp2
    MB: SM x5da8
    RAM: 3gb (with 3gb extended memory switch enabled)
    CPUs: Xeon 3.06
    Graphic: Matrox Parhelia 128
    Video Cap: BMD Extreme
    Sound Card: None
    RAID Controllers: 2 RAIDCore 4852
    Video Arrays: 2 RAID-5 (1.7tb ea)
    Sys Drive: 80gb WD eide
    Audio Drive: 120gb WD eide
  • Dkh Lai
    November 18, 2005 at 3:18 am
    Hi Claus-Peter Wolf and Bill,
    I’m also using BMD extreme with validated motherboard
    and system. I’ve been having this ” Adobe shutdown error ”
    problem and till now have no solution from BMD.
    Any idea of how to solve this problem after telephone session
    with Andrew-BMD Pc support?
    Daniel
