Activity › Forums › Adobe After Effects Expressions › 5 Minute Countdown
  • Dan Ebberts
    May 25, 2012 at 1:08 am
    You would need a more complex expression. Here’s one that uses a checkbox control on the text layer to drive the count down. The count only proceeds when the checkbox is in the “on” state.
    p = effect("Checkbox Control")("Checkbox");
    accum = 0;
    ct = inPoint;
    cv = p.valueAtTime(inPoint);
    for (i = 1; i <= p.numKeys; i++){
    kt = p.key(i).time;
    if (kt <= inPoint) continue;
    if (kt >= time) break;
    accum += cv*(kt - ct);
    cv = p.key(i).value;
    ct = kt;
    accum += cv*(time-ct);
    rate = -1;
    clockStart = 1440;
    function padZero(n){
    return ((n < 10) ? "0" : "") + n;
    clockTime = Math.max(clockStart + rate*accum,0);
    t = Math.floor(clockTime);
    min = Math.floor((t%3600)/60);
    sec = Math.floor(t%60); min + ":" + padZero(sec) + ":" + Math.floor((clockTime%1)*10)
    Dan
  • Akira Jun
    May 25, 2012 at 3:03 am
    Wow…
    Just wonderfull!!
    Thank you!!
    “Arigatou Gozaimashita!!”
    Jun
  • Chad Keddington
    August 28, 2012 at 10:05 pm
    Hi code works great but I am wondering if their is away to get rid of the leading number when they turn to zero.
    Chad
  • Dan Ebberts
    August 28, 2012 at 10:16 pm
    I’m not sure which version you’re talking about, but to eliminate leading zeros you would eliminate the call to padZero():
    rate = -1;
    clockStart = 7200;
    if (n < 10) return “0” + n else return “” + n
    clockTime = Math.max(clockStart + rate*(time – inPoint),0);
    t = Math.ceil(clockTime);
    hr = Math.floor(t/3600);
    “” + hr + “:” + min + “:” + padZero(sec)
    Dan
  • Chad Keddington
    August 29, 2012 at 12:46 am
    Hi Dan I am confused. Here is the code I am using. I want I five minute countdown. But when it gets down to just seconds I dont want the zeros to shows.
    rate = -1;
    clockStart = 300;
    Chad
  • Dan Ebberts
    August 29, 2012 at 2:08 am
    I’m still not sure exactly what you’re after, but try changing the last line to this:
    (min > 0 ? min : “”) + “:” + padZero(sec)
    and if that’s not it, try this:
    min > 0 ? min + “:” + padZero(sec) : sec
    Dan
  • Chad Keddington
    August 29, 2012 at 4:04 am
    That a little closer. What I want it to do is somthing like this count down from 5:00, 5:59,5:58…..4:00…3:00…1:00, 59, 58 …10, 9, 8, 7 … 1, 0
    Sorry for all the confusion
    Chad
  • Dan Ebberts
    August 29, 2012 at 4:27 am
    Now I’m confused. Isn’t that what the second variation from my previous post does?
    Dan
  • Chad Keddington
    August 29, 2012 at 12:07 pm
    The last post does do that except when it gets down to sec the semi colon is still showing. The previous one were I get ride of the call to padZero does count down in sec but does not show the minutes.
    Thanks for all the help.
    Chad
  • Ruben Gomez
    June 16, 2015 at 11:14 am
    Hi Dan,
    That script was very helpful…. Is there any way in the script that I can start the countdown after couple of seconds….
    rate = -1;
    clockStart = 300;
    if (n &lt; 10) return "0" + n else return "" + n
    clockTime = Math.max(clockStart + rate*(time - inPoint),0);
Page 5 of 7
