Activity Forums Adobe Encore DVD 18 Buttons Limitation?
  • Phil Condit
    June 14, 2011 at 3:39 pm
    Hey – it helps if I read the directions. Here is the screen grab I’ve been trying to send. It has 10 buttons, each with a subpicture highlight.
  • Daniel Ludwig
    June 14, 2011 at 6:14 pm
    hi phil,
    that menu is looking good – there should be no problems with this menu…
    cheers
    danny
  • Phil Condit
    June 14, 2011 at 6:42 pm
    Thanks for your help! So now I guess I have to go back to my original problem that when I tried to build the DVD I received a “Encoding Error” message with no elaboration. If my project checked out without any errors before I tried to build it, what can I look for now? Or should I start a new thread?
  • Daniel Ludwig
    June 15, 2011 at 7:55 am
    the error-message is encoding error!?
    so have you encoded your assets (films) prior authoring or not? it´s better to encode them using adobe media encoder first, then start authoring.
    NOTE: before you encode your stuff, you need to do a bitbudgeting.
    cheers
    danny
