Forums Adobe After Effects Saw teeth edges when using extrusion depth and 3d in AE
  • Saw teeth edges when using extrusion depth and 3d in AE
  • Christofer Kellgren
    September 29, 2021 at 9:19 am
    Thank you, that solved the problem!
    I thought that setting where just for preview purposes. Is there any panel that can manage the entire project (so you can work in lower fidelity and that just switch one buttom. Instead of doing it in every comp before rendering)?
    Attaching a img of the selector.
Viewing 11 of 11 posts
Log in to reply.
