Forums Adobe Premiere Pro RED footage importing as different color settings
  • RED footage importing as different color settings
  • Jonathan Henderson
    July 27, 2021 at 7:43 pm
    Something has changed, before when I would import my RED footage it would import with the color space and gamma curve settings I shot in, which would be rec. 709 and BT.1886. Now when I import footage it goes in as REDWideGamutRGB and Log 3G10.
    Before I was able to use RED CineX to save an RMD with the correct settings and it would work fine but now that doesn’t even work. Is there a way to set how premiere should import the RED footage? I am aware that I can edit one and save a preset, but then it applies white balance and ISO settings from that clip to all the others and its very frustrating and time consuming to go into every single clip just to change those settings…. does premiere have an option like Davinci that you can set the import settings? I can’t find anything on this.
Viewing 1 of 1 posts
Log in to reply.
