Forums Adobe Premiere Pro merge linked After Effects compositions into one .aep file (Premiere Pro)
  • merge linked After Effects compositions into one .aep file (Premiere Pro)
  • Arthur Bourquin
    July 27, 2021 at 9:13 am
    When creating dynamic link to After Effects compositions in Premiere Pro (and when it is not doing properly), it can create several After Effects files.
    How to merge thoses files into a single one without loosing the dynamic link or without having to relink them all manually?
    (In my case, I recieved a client’s project that is messy and want it to be clean.)
  • Adam Fischer
    July 28, 2021 at 11:29 pm
    The trick to having them all stay in one project file when they’re created is to keep the same AE project open in the background when you are creating them, so Adobe goes back to that same project each time.
    I think the only way to fix that AFTER they’ve been created is to import all the AE projects into one master AE project, then in Premiere go relink to that new project. I haven’t tried this, but I THINK you can highlight them all and relink the first one and it will figure out the rest. Kinda like when you move media and only have to relink one for Adobe to figure out the locations of the others. That’s not a quick fix but even if you have several project files this should only take a few minutes.
Viewing 1 - 2 of 2 posts
Log in to reply.
