Forums Adobe Premiere Pro automating in and out edit points on one clip
  • automating in and out edit points on one clip
    March 10, 2023 at 5:59 pm
    Hey Tom,
    Unless the Excel file has been formatted correctly, there is potentially a lot that can go wrong.
    I often get spreadsheets from my clients, with I/O points.
    My workflow is that I get the file that they want to work with. Pop it in a time-line and export that to MP4 with BITC for them to work from. That way I control the Time-Code.
    Then I start from the end of my time-line, by punching in the time-codes in PPro. And delete out what I don’t want – this is not going to take as long as you think that it will as soon as you get started on it + it also allows you to add that extra 10 frames when audio get cut short etc.
    Key point is “from the end” or you’ll lose position as soon as you do the first edit.
Viewing 11 of 11 posts
Log in to reply.
