Forums Adobe After Effects Aligning a 3D Layer to an Element 3D layer does not work
  • Aligning a 3D Layer to an Element 3D layer does not work
     Nicolae Tiberius updated 4 years ago 1 Member · 2 Posts
  • Nicolae Tiberius
    November 16, 2017 at 12:44 pm
    I have difficulties animating a simple camera pan over a 3D object extruded in E3D and a regular 3D layer.
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
    I created a null for the group from E3D. I copy position, orientation of that null and paste it into the regular 3d layer. I scale that layer align it perfectly but when I pan I end up with unwanted parallax .
    At the start of the pan the 3D layer and E3D object aligns perfectly but at the end of the pan the 3D layer is behind and not aligned anymore.
    I cant work out what to do.
    Thanks for any ideeas of what I m doing wrong.
  • Nicolae Tiberius
    November 16, 2017 at 2:27 pm
    I figured it out in the end for anyone else running into this problem I did the following:
    1. E3D effect I used Utilities / Generate 3D Position
    2. I used the select 2D Position than click Create 3D Null
    3. I than trim the separate 3D layer pre comp region of interest so the boundaries of the pre comp = the edges of the layer
    4. I moved the anchor point of the precomp to the top left
    5. Copy the 3D position of the Element 3d position, turned the pre comp to 3D and paste the position. I thank scaled the precomp down and is now perfect
Viewing 1 - 2 of 2 posts
Log in to reply.
